Reattaching imblem on trunk lid.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
The number 4 came loose from the trunklid of the Q and I want to glue it back on but not sure what glue would be the best to use. Anybody have any ideas? Thanks
MattJacksonville, FL
Rex
Car: None
More than likely anything you use will not hold as well as it did originally, unless you use super glue (NOT RECOMMENDED).
Try your local autoparts store for some "trim adhesive" or even swing by the local Nissan/Infiniti dealer and see if they have anything.
One other idea is to get a new set of emblems with the adhesive on them and replace them all.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Dennis said he uses simple RTV to attach his emblems......
tkd_q45
It's only $15 to get a new one. Has the adhesive on the back and is easy to place/stick down.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Plumbers Goop is the best will never come offf unless u want it to
szh
Car: 2018 Tesla Model 3.
Put it back on after the "5" and freak people out! "Q54"? Whats that?
Z
CrimsonQ
Car: Purple People Eater
yeah i had a Q4 for a bit
mattd1979
Thanks for all of your replies . I ended up using an addhiesive called Quick Grip and it seems to be working well so far.
