Reattaching floor mat
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
mahohmei
Car: 2007 Versa 1.8 SL, CVT
2007 Versa SL hatchback
We don't have any separate floor mats, however, there is mat on the driver's side, right next to the pedals, that's attached to the vehicle's carpet. It has come loose.
The vehicle is still within warranty, so I COULD take it to the dealer to have it reattached for free. I'd like to know if this is something I could safely take into my own hands, especially considering that the dealer would likely re-attach it using the same obviously-weak adhesive used at the factory.
How would you recommend re-attaching the rubber mat to the carpet? Gorilla Glue? PowerGrab construction adhesive?
Or should I just go back to the dealer and have them do it?
Thanks
Codelicious
Car: 1989 Nissan 240SX
If the dealer will do it for free than do it.
I wouldn't suggest glueing anything to your carpet in the car.. If you ever took those out it would look horrible.
dee_tymz_sl
Car: 2007 Nissan Versa SL Sedan
Codelicious wrote:If the dealer will do it for free than do it.
I second that... Anything the dealer will do for free let them do it
Return to “Versa Technical Discussions”
