DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri Oct 13, 2017 3:32 pm
My rule of thumb (and as mentioned prices can be up and down in different areas) is 4-5K MAX for a known well-serviced 120K or less NA (4K A/T, 5K M/T), and $7.5K to 10K for TT's. I honestly have little interest in Z32's with lower mileage than 100K, because the problems are all the same but you pay up for that low mileage just to still pay a ton servicing and maintaining the car.
By known well-serviced I mean no current issues or problems at ALL and recent (less than a year) 120K service performed by a reputable shop, preferably a Z32 specialist, and WITH RECEIPTS. Has to have had all known Z32 hotspots accounted for (injectors, wiring/connectors, clutch for M/T car, and brakes) to even consider those prices. I will not accept a car that has ever had a wreck or cooling issues unless the engine and cooling system were replaced with new OEM and with receipts, and the car cannot have electric fans in place of OEM cooling parts, period.
Then you have to be very careful inspecting the body, especially the lower rockers for rust and the front end for minor collisions. The Z32 nose section is the wimpiest mess I've ever seen and you can damage your car just falling against it, so look for the headlights to be level and aligned and with even gaps...anything off there means it HAS been tapped or worse. Under hood look at the top rail of the core support and if you can get under the car the lower one especially, looking for dummies who try jacking the car there and which will ruin that support and cause bad alignment and vague handling.
Check the paint carefully for respray, it's not uncommon a car gets touched up but you want the quality to be good if so, and do realize that in that case the car value moves down significantly from that top range also.
Check the doors for proper alignment and closing correctly, subframe and collision damage as well as bad hinges will make them drag and close oddly and for the windows to not seal correctly. Check ALL the rubber seals for pliability, old cracking ones will leak and need replacing and aren't cheap. Also be sure some kid hasn't jacked up the wiring in the DIN area with his bumper stereo he hacked in then tore out, a nightmare can await there and can keep your car off the road. Also be sure the car never was modded up and then the old parts reassembled as the PO keeps his toys...that car will not be safe since surely he didn't align the car and get things tuned up after such a venture, and you're getting the old parts that he replaced surely for more reason (suspension, brakes, wheels) than having a shiny toy.
Hope these things help, they may or may not be obvious but are some key issues you will want to avoid, and can easily pop up on cars that "look pretty good" on e-bay and elsewhere...do your homework and take your time, and do NOT accept stories in place of the items I listed here and other more obvious things...just keep looking!
Good Luck!
