PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Thu Jan 17, 2008 7:15 am
Eh, that manifold really isn't too bad. How much is the DC header?
I would DEFINATELY go with K&N. They have been around the longest, they have true musclecar/racing roots, and also have a million mile warranty.
If you get a cam and head work, you won't HAVE to change your A/F ratio at all. Your ECU does that automatically based on the factory tune. If you want to (and maybe make a few extra ponies) you would have to get a tuned ECU for your specific setup. Once again, if you have the cash, and want to do it, go ahead. It is another one of those things that will most likely not affect the way your car passes inspection (since most inspections are done under about 2700 RPM, where the tune will still have relatively stock parameters).
