Q45tech wrote:Stuff
As fascinating as it is to read about your manometer collection i would like it more if you could explain with some clarity your fuel damper theory.
I have noticed that some nissan engines have a fuel damper on the fuel rail and some do not have it. Even on the same engine it seems to vary, that is to say some rb's have a damper and some do not. This leads me to think that the effect is negligible at best or else it would appear on every engine.
However i do wonder about why there is a vac line on them. All the FSM's simply describe them as fuel pump pulse dampeners but the vac line does indicate a second function.
On the rb engines the damper vac line is connected just in front of the throttle body. This would indicate something to do with differences between manifold and inlet tract pressure. Although at WOT this pressure would be equal, not to mention what boost pressure might do at part throttle openings.
I then have to question how much, if at all this damper effects fuel pressure. It would seem to me that this could cause some potential problems with fuel pressure fluctuations if this is also in fact a 1:1 ratio regulator.
What is this graph you posted representing? Fuel or air pressure somewhere?
http://delphi.com/images/ppd/p...t.gif
You talk about 1/2 psi drop but the chart shows a fluctuation of 160kPa which is extreme.
