DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Feb 06, 2003 5:26 pm
I tend to agree with your tech on the freon. The AC is a sealed system. And it is under pressure. There shouldn't be any possibility of air or moisture getting into the system if the pressure inside is higher than the pressure outside. On rare occassions, the compressor can create a vacuum on the low side, allowing air to permeate (VEEEERY slowly) through the hoses, but I believe it is to a very small extent. Air won't harm the system, though it will decrease its efficiency. Moisture (in the air) is bad, as it forms an acid inside the R-12 system, destroying the compressor over time. That's why the system has a drier that contains a dessicant. It's a cost/risk issue. How much would it cost to change the freon and the drier? How much would it cost to do all that PLUS flush the system AND change the compressor? You could change the freon now, but considering the age of your car, your compressor could go in a couple of years, and you would have to do the whole shebang then anyway (freon, flush, compressor, drier).
