Rearview mirror
RiverRogue
Car: 2008 Nissan Rogue
The rear view mirror on my Rogue is loose and vibrates when driving.
Any idea where the set screw is? Do I have to remove a platic cover?
Thanx!
RiverRogue
Found it.
A small plastic cover covers the set screw that holds the rear view mirrow onto a metal piece glued to the windshielf.
Pry the plastic piece off, get the appropriate sized allen, tighten. I added some blue locktite to the set screw to avoid it backing out again during driving.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
This could prove useful to someone. Nice post.
Return to “Rogue Forum”
