Like I said, R34 is taller than 4.11:1, not shorter.elwesso wrote:well then maybe it was a 4.36 from a R34 rear diff...
The aftermarket LSD doesn't give you the stronger axles, and is much more costly than a GTR rear.Chrispy300 wrote:For you guys in the states you would be better off chucking in a aftermarket LSD centre rather than trying to source a GTR diff. I'm sure they wouldn't be cheap over there. There not even that cheap over here
Most US Z's are NA, so there is no subframe compliance issues really.Chrispy300 wrote:Bit of a PITA trying to fit GTR diffs into the Z too. You need the NA subframe, TT halfshafts and hubs. Not sure what you do about the toe rods either. They may fit on the TT hubs.
I thought it was quite reasonable. And I've seen others for similar prices.Chrispy300 wrote:That's a pretty good price for the entire rear end...
The knuckles are not interchangeable from NA to TT, the TT knuckles have the bushes that are designed to bolt to the HICAS tie rods, the NA knuckles do not. The HUBS are not interchangeable either, TT is a higher spline count than NA, but the TT hubs can be put on NA knuckles, allowing the larger spline count axles to be installed in a subframe without HICAS. Since the GTR rear is an R200, it can be bolted into the non-HICAS NA Z32 subframe as well. The last component is finding axles that are the right length.Chrispy300 wrote:You sure the hubs and knuckles are interchangeable? Why are there different bearings for the TT and NA hubs?
Chrispy300 wrote:Most of the Z racers over here use the R32 GTS-4 diff due to the 4.3:1 ratio. But that's a 5 bolt R200. But that is circuit racing with TT VG's, no 'proper' drag cars as such.
Maybe just stick with the R230. There are a couple of LSD centers available, and Richmond make the 4.1 gears for it if required.
Always an optionChrispy300 wrote:Ford 9"?
I'm sure that would work as well, just measure the difference in width between the R230 and the R200, divide by two, and you have the thickness needed for your spacers. If it is less than 0.100" I would say they aren't needed at all.John Dixon wrote:I'm assuming that I'm going to be able to use the TT driveshafts and make up some spacers to get bring the R200 output flanges to the same width as the R230 ones. Mainly because I have 3 sets of TT shafts alreay!
