DamonQX4 »
https://forums.nicoclub.com/damonqx4-u123949.html
Mon Jul 06, 2009 12:06 pm
It probably just needs to be cleaned up. Just take apart your back. Two screws on the handle and a bunch of clips.
remove the arm from the motor and see if the motor moves freely. If yes, then you should notice that the inside linkage arm attached to the wiper is stiff. you will have to work in some lubricant from the outside. It's better to take off the outside wiper arm and work the lubricant around the rubber washer.
That should do it. Proper occasional maintenance will keep you wiper motor from breaking.
Hope this helps.
