rear wiper...
07phil
Car: rogue sl awd 08
Hi guys... It's my first time on nicoclub. I 'm sure I will find lot of stuff for my rogue.
But first, I need help. Yesterday I remove my broken rear wiper arm... VERY hard to remove.... I broke my wiper motor plastic case... I remove it to fix it and, when I put it in my hatch....NOTHING...! I don't have any power on my wiper wire... Fuses are OK. (under hood and driver side) So what's happens??? Any help will be appreciated...
Many thanks
p.s. I speak french... sorry for my english!
07phil
...WTF.... When I plug 12V from inside the house, motor works. When I put in car: NOTHING !!! Is there a hidden fuse for rear wiper!!! Owner manual sucks about that...
thanks again,
Phil
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Check fuses #4 and #6 in this diagram:
Welcome to NICO.
07phil
thanks...but where is this fuse block? I have '08 SL basic AWD Rogue (canadian) It's not same schema under my driver side dash and under air filter...
Towncivilian
I'd assume it'd be one in the cabin somewhere. I don't have a Rogue to reference, so unfortunately I can't offer an exact position. Sorry! The factory service manual listed fuses no. 4 and 6 as having a part in the rear wiper motor operation.
07phil
all right but, Is this factory service manual is for a rogue? Will double check... even my dealer don't know wiper fuses... Do you know BCM (body control module)?
thanks again!
Towncivilian
Yes, I got that picture from a 2008 Rogue FSM. Download the FSM here. To save a copy of the FSM, right click -> Save As on every PDF, save them into a single folder, then use fwd.pdf to navigate.
07phil
great, but I think is for a 2008 versa ( if I click your link) Do they have it for rogue? I will try to find...
Towncivilian
My apologies, I provided the wrong link. Here you go: http://www.nicoclub.com/FSM/Rogue/2008/
I also provided the wrong fuse box layout! I don't know why I thought you had a Versa. Sorry :confused:
There is a diagnosis procedure in the WW section of the FSM.
07phil
I got it !!! I'm almost there...!!! but cannot find trouble.... It's about BCM... maybe will go to dealer.... Thank you so much for your help and time...! I'm very grateful !
07phil
FYI: The reason why I don't have any power on rear wiper harness is because wiper motor wasn't fix correctly ( wasn't timed to swivwel right and then comeback left...) and he plugged to the harness..!!! So once I fixed correctly the inside of the motor AND I plugged to harness, evrything works fine !!! Thanks for schema Towncivilian !!!
Towncivilian
Glad to hear you fixed it. You're quite welcome. :)
07phil
hi leona, what's the problem... ? For rear wiper, there is about 4-5 fuses and relays working toghether... Not only one...
Return to “Rogue Forum”
