The special rear wiper blade is available for the special rear arm. Look online for a "Trico Exact Fit Rear Integral Blade". There are several variations for the handful of specialized rear arms out there so make sure you enter your make, model and year so you get the right one. Install is super easy. Hope this helps.ronswarrriors wrote:Has anyone attempted to replace a worn rear wiper on an '08 Quest? Do I really need to replace the entire arm $38 dollars?!!
Unless you go with the suggestions below, it is indeed the ENTIRE WIPER ARM from Nissan. Ridiculous -- that blade used to be sold alone from Nissan (at least for my 04, I bought one years ago)...but not anymore!!! Last time I purchased, I had to get the whole arm. The only good thing is it did last quite a while, even in a dry, snowy desert.ronswarrriors wrote:Has anyone attempted to replace a worn rear wiper on an '08 Quest? Do I really need to replace the entire arm $38 dollars?!!
