Rear windshield wiper vibration on hatchback
rdsworks
Car: Versa '08
Alrite, So if anyone out there has subs in the back, do you find that the wiper vibrates like crazy?
Does anyone know of any mod I could do to reduce the vibration?
blindsnyper
Car: 2007 versa
mine does the same thing, i just deal with it
JoshH
Car: Nissan Versa S 2007
Subaru BRZ 2013
When I first installed my sub, my wiper would vibrate like crazy. I then took off the panels of the hatch, added 2 layers of RAAMmat BTX (butyl mat), 1 layer of 1/4" closed cell foam coupled with 1/4" of vinyl, and then filled the entire open space with expanding foam (Great Stuff from home depot). The trunk is basically like a brick now and doesn't move even at the max volume.
So far, I've added 60sqft of butyl mat, 50 lbs of closed cell foam coupled with vinyl (2lbs/ft^2), 3 yards of ensolite (1/8" closed cell foam mainly for vibration dampening between the panel and door), and have filled all the spaces (above rear wheel wells and trunk hatch) with expanding foam.
blindsnyper
Car: 2007 versa
JoshH wrote:When I first installed my sub, my wiper would vibrate like crazy. I then took off the panels of the hatch, added 2 layers of RAAMmat BTX (butyl mat), 1 layer of 1/4" closed cell foam coupled with 1/4" of vinyl, and then filled the entire open space with expanding foam (Great Stuff from home depot). The trunk is basically like a brick now and doesn't move even at the max volume.
how much weight do you think you added?
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
How much storage space was lost? I thought that was the deal with hatch vrs sedan.
JoshH
Subaru BRZ 2013
To the hatch alone? Or altogether? Altogether - I know for a fact I've added 47.5lbs of closed cell foam + vinyl. I believe the raammat was around 30lbs or maybe more/less. The ensolite was very light, a few pounds. The expanding foam is also very lightweight - I would guess a few pounds total at most.
In the future, I plan to add more closed cell foam coupled with vinyl - I've only done the back half of the car with it so far. It really kills road noise like no other (vinyl is a great barrier - especially coupled with a layer of closed cell foam below it).
