too bad the rear fluid dispenser is not run under the car, you would have made this girl look like a dumbass looking under her car, the line is run inside the car under the carpet.CodeRed wrote:hold it for about 10 sec then look under your car and see if there is any dripps if there isnt but there is some by the trunk open the hatch and look at where the third brake light is you can pull off that entire peice and see if the host is snapped or clogged
well it could be leaking from the engine compartment ohhh burn!Clipsed wrote:
hahaha, silly clipsed always so one dimensional.CodeRed wrote:well it could be leaking from the engine compartment ohhh burn!
not really, but you are not in compliance with the signiture rules. You are allowed to have 235px of text ONLY, or 2 lines of text along with a picture, and seeing as how you have a picture, you are only allowed 2 lines of text. So hopefully EV changes yours just as he did mine.CodeRed wrote:well it could be leaking from the engine compartment ohhh burn!
sorry for what i said (forgot what it was) but, Clipsed and I are cool, we talk off the forum all the time sorry thought it would be taken as a joke.proxim2020 wrote:And for the rest of you. Please act like you have some damn sense. Finger pointing is just soooo immature.
Thsi would also be my first guess. For the rear wiper you push and hold the windshield wiper stalk stalk away from you. For the front you pull and hold t towards you. It took a few minutes ot figure out, but it's also in the manual.GoodbyeCavalier wrote:I had the same issues. Its very simple i wanted to smack myself on the head and speak of it to no one, but a girlie in trouble hard not to help.Anyway it seems to me that the line isnt primed off the manufacturing plant. you have to hold the rear window spayer for a while, I believe pulling the blinker switch towards you. Eventually it will go and you wont have this issue again (unless the nozzle does get clogged or something happens in the line)
Good Luck hope this helps.
Ok, I understand. Next time make sure you give some type of indication that it's a joke or something. We have a lot of members and fires between them pop up all the time. It's not easy to tell between a rift and a joke between members. We really don't know who's homies and who's enemies.CodeRed wrote:
Funny you should bring this up, Wayne, since your sig is STILL not compliant... your text is too wide, and ends up being 4 lines.Clipsed wrote:
Ah, the good ole days.Jemdawg wrote:I'd like it if I could go to a thread and read about solutions to the problems presented, and not a back and forth psuedo-argument which takes up most of the thread.
