Postby
DocPlez »
https://forums.nicoclub.com/docplez-u45972.htmlWed Oct 25, 2006 4:34 pm
I noticed a problem with my Versa a few days ago (it's probably never worked but I've never used it before). The rear window washer motor runs but the nozzle over the window sprays no washer fluid. I can feel the rubber tube pressurize at the left side of the hatch and I've cleared the nozzle but still nothing. The tubing actually goes down into the hatch towards the bottom and not over to the nozzle. Anyone else have this problem?
Postby
Althalus »
https://forums.nicoclub.com/althalus-u47444.htmlWed Oct 25, 2006 7:32 pm
BenzTech Gone Versa wrote:mine works but it comes out very little,not like the front.it just has a stream instead of the high pressure spraying.
I've gotta stream too.
Something else i've noticed, while going through auto car washes the little cover for the bolt comes up and flaps around, anyone else have that problem?
Postby
cireecnop1 »
https://forums.nicoclub.com/cireecnop1-u45257.htmlThu Oct 26, 2006 9:12 am
I only get a streem of fluid too! it kind of sucks, i tried to put a needle in the nozzle to move it around and it seems like it is in a fixed position. .
Postby
DocPlez »
https://forums.nicoclub.com/docplez-u45972.htmlThu Oct 26, 2006 6:06 pm
I have no idea what bolt he's talking about .... however, I cleaned the rear window washer nozzle with a .020 wire gauge but still no luck. The wire went in about 1/2 inch and stopped at the turn on the back of the nozzle tubing.
I'll stop in and have it checked next time I'm in Las Vegas.
