Rex »
https://forums.nicoclub.com/rex-u6324.html
Sat Jun 26, 2004 9:56 am
AZ's right on, the problem is removal. Almost anything you use to remove it will also be removng the defroster as it's a layer of clear adhesive with the defrost wires sandwiched to the window.
The only suggestion I can give is try to find the seam in the middle of the window and remove it towards the edges. The defroster "layer" has no seam and should only come up from the edge. Make sense?
