Rear window defogger
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Element41
Car: 2008 G35
I recently purchased a 2008 G35 sedan. The rear window defogger is pathetically weak. Have others had the same experience? I'd like to get a feel for what I'm dealing with before I go do the tango with the dealer maintenance department.
Lenny
zozoka1212
Car: 08 Infiniti G35x
Mine works like a charm. I have little cooler weather than you. No issue here.
zozo
smockers83
Car: 2006 G35 Coupe
I remember one other person ever complaining about it and we determined that he just didn't understand why windows fog up.
What's your definition of weak?
Element41
Car: 2008 G35
Let's see: Something on the order of 35-38°F OAT. Dew or light frost on the rear window and 10 minutes to clear enough to barely see out the rear view mirror. By that point the engine was warm and the heater had warmed the cabin enough to do most of the job.
All the elements in the window are working as the dew slowly clears evenly from each the heating element lines.
Compared to any other car I've driven it is very slow. On a plus note the heated side view mirrors are clear of dew in a minute or two. They work great.
It's either a design problem or somethings wrong. I suspect I'll get the former answer from the dealership.
Lenny
smockers83
Car: 2006 G35 Coupe
Yeah, it's hard to say without being there. I guess you'll have to go to the dealer to really see, or get someone to do a side-by-side comparison with you.
I also tend to think that the weather stripping is leaky on some of these cars...sometimes my windows fog up for really no reason.
pfarmer
Car: 2008 GXS with technology package
Element41 wrote:Let's see: Something on the order of 35-38°F OAT. Dew or light frost on the rear window and 10 minutes to clear enough to barely see out the rear view mirror. By that point the engine was warm and the heater had warmed the cabin enough to do most of the job.
Lenny
I have an 08 XS.
I don't think mine is as weak as you may be describing, however compared with my other cars a little weak. If we are just talking about dew, not much difference there, however if speaking of clearing a window of ice, I resort to the scraper earlier than my other car.
On my second car I can actually see the rear window steam at times, so maybe it is not really a good comparison as it seems to work better than most others I know of. On the other hand, on my XS I can see the mirrors steam while with my other car I can hardly tell the heaters function at all.
I basically scrap enough to see well and then drive up nice and slow until it warms up. I only vary this routine if there is enough snow to present a problem going up the hill next to my home.
Perry
Element41
Car: 2008 G35
Thanks for the responses. On some of the other forums this seems to be an issue with the G35. Lots of complaints. Looks like mine is functioning "as designed."
Return to “G35 and G37 Interior, Exterior and Audio”
