vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Thu Feb 20, 2003 2:49 pm
The power antenna wire is for operating the mast. The antenna mast and window antenna are connected together. I assume if you are using the mast , you are using the window antenna.Not sure how you connect the antenna lead to a non factory deck.I have to check to see if i have a window antenna on my 1991.
