Rear widebody fenders / quarters ?
Z28ricer
Car: Cars
Anyone have experience with any of the msports / charge speed / d-drug wide body rear fenders, specifically they seem to be complete quarter panels, for the installation do you completely remove the stock quarter panel and install them in place, or are they some rediculous glue to the side of the car deal ?Any help is appreciated as i've done a good bit of searching around and cant find much for actual install instructions or a possible write up from someone whos installed them.
Vashxthexmonkey
Car: 240SX
Rear quarter panels MUST be done at a shop w/ good credibility. Once you get those rear fenders, and you take a look at them, you'll know what I mean. There is no glue, double sided tape, or anything of the sort. It must be molded on by a proffessional.
Unless you consider yourself a proffessional, then go0dluck to you ;]
s13 240
Car: 1990 Nissan 240sx
rivet them bishez on
Z28ricer
Car: Cars
Thanks for the pic, I found it a little while after creating this post from a lot more searching, while I have no doubt about installing them myself properly, I really dont see the possibility of the fitment of them ending up good enough for my plans without being a complete replacement quarter panel, which would be awesome if someone duplicated a stock like metal quarter thats wider like the "overfenders" . Thanks for your input.
