rear wheel studs
JsickZ32
Car: 1990 300zx 2+2
hi, i need to replace my rear wheel studs and i was wondering if i have to remove the hub? if so what size is the bolt that holds it in place? i did my fronts today and they were easy but then when i tried to replace my rears theres no space to remove them. i looked for write ups but all i found was for the fronts. thanks
robomatic12
Car: 1990 300ZX TT
You do not need to remove the hub. If you rotate the hub assembly you will notice an area that will allow enough room to knock the wheel studs out.
