machuelo wrote:I like to know the procedure to chenge the studs form the rear wheel and where find it and the price of it.
I did it a couple of weeks ago. Easy job. I found AZHitman's post about replacing studs and followed. I replaced all 4 corners with 50mm Nismo studs. It was $6 each. If you get Nissan OEM it's like $1.50 each or something like that. Remove wheel, caliper, hammer out old stud and put a new one back in using washers. Use PB Blaster. It helped a lot. Torque spec is about 80-85lb. To buy studs, just go to your local dealership. They should have them in stock. If you get them online, you have to pay more for S&H.
This is picture of rear...
Modified by 94_240sx at 5:35 AM 9/22/2006
