rear wheel steering
93RPS13
Car: Cars, Girls, Cars, Food
does rear wheel steering(RWS) get affected is you install a different LSD? And does RWS work when you swap engines ie RB25DET?
f8sjester
which car in the nissan line-up has rear-wheel steering? or are we talking HICAS? if we are, then i'll shut up. . . i dunno anything about HICAS. . .
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
HICAS IS ESSENTIALLY RWS. BUT FROM WHAT I WAS TOLD THE DIFF CHANGE MAY CAUSE PROBLEMS BUT SHOULDN'T AND WITH THE RB MOTORS MOST THE SKYLINES HAVE HICAS, SO TO ANSWER YOUR QUESTION: NO IT SHOULDN'T.
93RPS13
thanks so if i which the the stock S13 LSD with a R32 GTR lsd everything should be ok
PROJECTRB240SX
YEAH ACTUALLY YOU MIGHT WANT TO USE LIKE A SILVIA LSD BECAUSE YOU'LL GET ALOT BETTER ACCELERATION OUT OF IT. COMPARED TO THE LOWER WHEEL RATIO OF THE GTR'S. THE HIGHER THE NUMBER THE QUICKER THE ACCEL, THE LOWER THE NUMBER THE HIGHER THE TOP SPEED.
93RPS13
do you happen to know if the GTR is a 1, 1.5, 2.0 way LSD?
PROJECTRB240SX
THAT I'M NOT SURE BUT I'M THINKING ITS A 1 OR 1.5
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
I miss HICAS. . some people hate it, but gawd what a nice system. :cool:
Wish S14 (other than silvia) came with it. . stock handling in my S13 was better than most modded S14s.
KoukiS14
BTW. . YOU DON'T REALLY NEED TO USE CAPS HERE, WE'RE ALL GROWN UP AND CAN DIFFERENTIATE BETWEEN CAPITAL AND LOWERCASE STUFF.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
well hicas is more than just the diff...it's a comptuer controlled ssytem from what i know and involves a diff rear control arm...among other things
nametakennow
Car: '06 MINI Cooper S
KoukiS14 wrote:BTW. . YOU DON'T REALLY NEED TO USE CAPS HERE, WE'RE ALL GROWN UP AND CAN DIFFERENTIATE BETWEEN CAPITAL AND LOWERCASE STUFF.
Read his sig... though at this hour I bet he's not at work...
KoukiS14
sorry :Dhey, who wants to see some pics of totalled rice?!
KoukiS14
nametakennow wrote:Read his sig... though at this hour I bet he's not at work...
I know I know. . hahaI'm not REALLY a **** lol
I came back in and read that and I was like "wow. . what a$$. . ohh that's me"
KoukiS14
mainevent212 wrote:well hicas is more than just the diff...it's a comptuer controlled ssytem from what i know and involves a diff rear control arm...among other things
the ENTIRE package consists of rear wheel steering (speed sensitive, electro-hydraulic controlled), thicker sway bars, stiffer springs, tighter ratio steering, VLSD. .
at low speeds, the rear wheels turn in the opposite direction as the front (only by 1-2 degrees). . at higher speeds, they kick opposite of the front for a bit, then turn and settle in the same direction. . the reason for this is to sorta. . tighten up the steering a bit. . the system is awesome, IMO. . .95g on skidpad, with h rated tires. . .88 without hicas. .
a certain Don Nimi hit 1.22, and held at 1.14 by ONLY changing his tires to r compound racing tires. .
