rear wheel spacers 20mm front wheel spacers 15mm
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
recently i purchased a pair of ichiba hub centric rear spacers and some front ichiba hub centric rears spacers the rear seems to be fine but the front is giving me trouble. when i get to 40-45 mph my steering wheel begins to shake it doesn't swerve to any side just shakes badly. has anyone else had this problem?? if so what are some solutions? Ive already balanced the wheels and had a wheel alignment, and the power steering rack and bearings are good so i am a little stumped... :confused:
costa_rican13
Car: 1993 s13 coupe
Same problem awhile back. it my was inner tie rods/outer tie rod ends. jack up one side of the car. And shake the wheel. If there is any play in it, then its bad and needs to be replaced. also this is one side at a time. not just jack up the front but only one side of the front at a time. then check for play.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
they're new tie rods now the wheels aren't hub centric would that affect it??
costa_rican13
Car: 1993 s13 coupe
It might due to them not being completely even with the hub and driving they probably slop around the hub causing the shaking. Only way to find out it out is put different front wheels.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
well i have some hub centric rings i just got going from 73 mm to 66.1 mm no the spacer hud is 66.1 should i have gotten a bigger hub centric ring? or should it be fine?
Gabes13
Car: rb20det s13
I think the 240 hub is 66.1, so you should be fine, as long as the wheels you have are a 73mm bore.
I had this problem awhile back when I bought spacers for my xxr wheel. The wheels with spacers would shake at upper speeds but stock wheels w/o spacers would ride so smooth as butter. I got some hub rings and it helped a lot. I also installed energy suspension rack bushings and that helped more. Costa Rican is right about the tie rods too though.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
alright thanks for the help i got the rings in the mail today and gonna put them on :biggrin: i appreciate all the help!
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
back again with more shake got the right hub centric rings helped a little but the shake is still there i replaced the studs in front with longer ones all the bushings are new and tie rods are brand new too could to man weights on the wheel make the steering wheel shake? not sure what else it could be :confused:
Gabes13
Car: rb20det s13
You might have some air in your steering rack. Have you tried bleeding it?
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
yeah :/ when i take spacers off its perfect maybe warped spacers? hmm this saterday ill take it all apart clean then check and put it back together and add the status after
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
ok so spacers are not warped but without them no shake with them shake at 40-50 pretty bad to still stumped :/
