Actually it's possible since the stock rev limiter/speed governor will keep the car from reaching peak HP. Most folks raise the limiters on a custom tune, which allows the engine to extract maximum HP. I believe you can get the 9-10 increase without any mods, just by increasing the rev limiters/speed limiter.
I agree.armybrat wrote: ↑Thu Jul 12, 2018 4:11 amActually it's possible since the stock rev limiter/speed governor will keep the car from reaching peak HP. Most folks raise the limiters on a custom tune, which allows the engine to extract maximum HP. I believe you can get the 9-10 increase without any mods, just by increasing the rev limiters/speed limiter.
Yep. You can also get more power out of the y51 V8 now with the unlock of VVEL. Only one person has done it so far but we have not heard anything from him in a while on the forum. Think he was from Texas and Nico name started with a DFS or something like that. He probably has the fastest NA M56. Russ Smith has the fastest and only Twin Turbo M56 that we know of in the states and probably world.Ilya wrote: ↑Thu Jul 12, 2018 7:49 amInteresting...fair enough. I was always under the impression back from the Nissan Maxima days that most of the time, a CAI might actually rob a hp or 2 as they more often than not suffer from heatsoak. So given a best case scenario, I figured only a few hp might be gained. Didn't realize raising the rev limiter had such a drastic effect on the Y51.
In all fairness, the OP didn't really clarify what type of CAI he installed. (long tubes or short tubes)Ilya wrote: ↑Thu Jul 12, 2018 7:49 amInteresting...fair enough. I was always under the impression back from the Nissan Maxima days that most of the time, a CAI might actually rob a hp or 2 as they more often than not suffer from heatsoak. So given a best case scenario, I figured only a few hp might be gained. Didn't realize raising the rev limiter had such a drastic effect on the Y51.
Does Russ have a thread on here with twin turbo or any youtube videos? Do you know if it is running ok with the twin turbo?walt1227 wrote: ↑Thu Jul 12, 2018 9:06 amYep. You can also get more power out of the y51 V8 now with the unlock of VVEL. Only one person has done it so far but we have not heard anything from him in a while on the forum. Think he was from Texas and Nico name started with a DFS or something like that. He probably has the fastest NA M56. Russ Smith has the fastest and only Twin Turbo M56 that we know of in the states and probably world.Ilya wrote: ↑Thu Jul 12, 2018 7:49 amInteresting...fair enough. I was always under the impression back from the Nissan Maxima days that most of the time, a CAI might actually rob a hp or 2 as they more often than not suffer from heatsoak. So given a best case scenario, I figured only a few hp might be gained. Didn't realize raising the rev limiter had such a drastic effect on the Y51.
There is one or two youtube videos from a few years back when it was in development. Think it was Dyno runs where they were testing it. Russ has posted some freeway pull videos on the Infiniti M35,37,56 FB group but I don't think there are any others outside of that.Dicemoney6 wrote: ↑Fri Jul 13, 2018 6:46 amDoes Russ have a thread on here with twin turbo or any youtube videos? Do you know if it is running ok with the twin turbo?walt1227 wrote: ↑Thu Jul 12, 2018 9:06 am
