Rear wheel alignment question
MR. Q
How do you max out the rear wheels. Meaning that the wheel is 100% tread on road. I know of the upper control arm with the numbers on it. So I'm wondering is left ratchet bringing the wheel in or is right ratchet?
Q45tech
The tread is always on the road, however the camber [neg , zero, positive]shifts the vehicle weight distribution across the face of the tread.
With new bushings and unbent arms the factory decided negitive 1.1 degrees STATIC CAMBER worked the best at 60 mph.
