Rear view camera
All things Altima Coupe.
Infantry1327
Car: 08' Nissan Altima Coupe SE
Ok I really love my rear view camera, but does anyone know how to make it so you can view your rear view camera while you are driving.
mcheddadi
Car: R8
don't let go of the cluth and put it in reverse if you have a manual then put it back in the same gear it was.
if you have an automatic you can't lol
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
mcheddadi wrote:don't let go of the cluth and put it in reverse if you have a manual then put it back in the same gear it was.
that sounds pretty dangerous to do when you're driving at 100 km/hr don't you think?
mchedaddi wrote: if you have an automatic you can't lol
and yet another negative of factory nav vs aftermarket ... lol Aftermarket DVD/NAv FTW!!!!!!!
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
WHAT!?!?! The a/c 6 speed lets you put it in reverse, with the clutch pushed in, while your driving forward? That doesn't make sense, the lock out mechanism should definitely keep that from happening
spockrock
Car: Altima Coupe 3.5se
adidas2go wrote:WHAT!?!?! The a/c 6 speed lets you put it in reverse, with the clutch pushed in, while your driving forward? That doesn't make sense, the lock out mechanism should definitely keep that from happening
It shouldn't I know mine wont.
{WBK}Viper
If your car will go into reverse while traveling more than 3 mph forward...there is something wrong with your car...AND
You will completely fug up your trans.
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
{WBK}Viper wrote:If your car will go into reverse while traveling more than 3 mph forward...there is something wrong with your car...AND
Not Necessarily:
http://auto.howstuffworks.com/car-in-reverse.htm
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
The fact that someone tried putting their car in reverse (with or without clutch being held) blows my mind.
I felt like i was cheating when i put my car in NEUTRAL when i was moving... sheesh!
Theres no hack for the stock navi to allow it?
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
There's no way you can put it into reverse while your driving. The syncro-gears and lock out will prevent idiots from doing that
Infantry1327
yea i understand the hole not throwing your car in reverse. But i was just wonding if there is any way to trick the system. I know you can trick the nav into thinking the car is stopped while you are moving, but does any one know how to do something similar to the reverse camera.
hopetriumphs
Car: 09 Infiniti G37
how do you trick the nav into thinking youre moving?
Infantry1327
I dont'y like sending people to nissan club, but this should hopefully answer your question about the nav hack.
http://www.nissanclub.com/foru....html
nightrain
Car: 2008 3.5SE
Dude. It's simple.
Drive backwards.
Modified by nightrain at 10:29 PM 6/26/2008
Infantry1327
tried that, but the cops werent to happy
