kinfer »
https://forums.nicoclub.com/kinfer-u137218.html
Mon Aug 03, 2009 3:17 pm
I was going to check the driveshaft today, but my friend is borrowing my jack. It's wierd because everything was fine yesterday. If driveshaft is fine, where else should I look? I took a peak of the underside from the side and the diff seems to be covered in oil. But then again my whole engine is took (leaking oil =P). I really doubt that coolant is the problem. I reved the engine a little bit after I pulled over to check it out, and motor seems fine. It's only happening when going >40mph. I'm broke right now...literally, so I can't spend any money until Friday. So I guess I'll check driveshaft, then I'll try to change the diff oil, then I'll get a balance. Is there anything else I should add to my to-do list this week?
