rear upper control arms
goldollar
Car: cars
ive been doing research on ways to fix rear camber issues and i searched the fourm, and i got differnt answers like, ingal camber plates, longer bolts or something like that, and rear upper control arms. Well i didnt get any real good info. what i want to know is will upper control arms fix rear camber, and how well. or are there cheaper and better ways at fixing camber
F4ucc
Car: motorsports
Well, since I am using Cusco Rear Control Arms, don't have any experience w/ those camber correction kits or whatsoever.With Adj rear upper arms, you could have widerange of camber adjustment, as for installation, it's a simply bolt on.
I've heard many people complain about the installation for those correction kits. Anyway, I guess unless you drop your car more than 2", correction kit should do ok.
cheers
goldollar
Car: cars
thanks man thats all i wanted to know
StanBo
Car: 93 Mazda Miata
10 Toyota Tacoma
F4ucc wrote:Well, since I am using Cusco Rear Control Arms, don't have any experience w/ those camber correction kits or whatsoever.With Adj rear upper arms, you could have widerange of camber adjustment, as for installation, it's a simply bolt on.
cheers
How was the setup of the camber? My friend has the JIC arms and took the one he put in out because he was having a ***** of a time getting the camber correct.
