Rear Toe question?
300bucks
Car: 1988 Conquest Ls1 powered
My car has been lowered with kybs and tein springs, and the rears are toed in like a *****. Its wearing tires horribly (outsides) even though its got negative camber. Is it possible to adjust the toe in the rear? It was like this when I bought it.
1992 s13 hatch
thanks
180fan
Car: 89 fastback
yes ala the toe links' bolts. take it to an alignment shop.
KFL
Car: S14
Max toe adjust is only .25 stock arm, if its more than that you will need aftermarket adjustable toe arms. Toe kills tire faster than camber.
Vidra
i thought if your tires were toed in that the insides would wear and not the outsides? hmm, anyways, I was wondering the same thing... cept i got inner tire wear due to toe (camber has been adjusted with ruca's)
blinker_fluid
Car: 1991 Nissan 240SX FB
2000 Nissan Maxima SE
i just put on adjustable camber and toe links but can't find any shop to do the alignment. they say they won't touch a lowered car wtf!
spinitsidewayz
Car: 89 Fastback
DIY alignment ftw.
http://www.negative-camber.org....html
