Hi all,
So I did get the lowering springs in. Went with Godspeed springs and they are good so far and not dropping a lot to scrap everything. I took the car for a 4 wheel alignment and they fixed the front toe from around 0.20 to 0.02. I'm concerned about the back though, as the toe is still 0.20 on one tire and 0.08 on the other. Is this not problematic? Is there toe adjustment for the rear tires? I purchased camber bolts for the rear tire, but I'm not sure where to install them, I'm assuming the lower control arm on the outer bolt? Can anyone confirm?
Thanks!
