NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Apr 24, 2005 9:22 am
toe is the difference between the center line of the front of the tires to the back of the tires. In other words take a tape measure and center it in the middle of the tire tread,stretch the tape to the otherside of the car and place it in the exact same spot on the other tire. Write down that measurement. Now go to the back of the tires and measure in the same spot as you did in front of the tire. Write down that measurement. Now do the math, deduct the lower number from the larger number this will give you your total toe. If the higher number was at the rear of the tires, it is toed in. If the higher number was at the front of the tires, it is toed out.
your spec is .020 to .177" in [.5 to 4.5mm] toed in.
