jp86 »
https://forums.nicoclub.com/jp86-u26343.html
Sun Apr 24, 2005 8:04 am
ok folks..here'e the deal..i dropped my car on coilovers and got rear camber arms, and got an alignment. and found my rear toe to be -0.42" left rear and -.34" right rear.
now I just got my adjustable rear toe arms and need to know how much to adjust them, I know they need to be longer then my oem toe arms but by how much exactly?
what i need to know is how my rear toe is measured??
-is the 0.42" the difference between the most frontward edge of the rim and the most rearward edge of the rim??
-or is it the difference between the center of the rim to the most frontward edge..
-or is adjustment gonna be a ratio of the measured toe because the rear toe arm is 2/3 the way fron the rim centerline to the most rearward edge of the rim?
or is the 0.42" exactly the amount I need to lengthen the toe arm to get 0 toe
the reason why i'm asking this is that I need to install these myself because the nearest alingment shop is 2 hours drive away, and with that kinda rear toe I don't wanna drive on my brand new rubber that far again.
jp
