OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Tue Jul 05, 2011 6:09 pm
Well the rear doesn't have a spindle. It has a splined axle shaft which slides into the rear hub and gets bolted in. The rear hub is bolted to an iron upright. I would very much doubt that the issue lies within this. However I would remove this wheel and jack the rear of the car up, and pt it in reverse VERY CAREFULLY. And use a solid surface (like a milk crate) and a flat ruler can bring it in to the very edge of the brake rotor and look for visible wobble. Then put a known good set of wheels on the back and see how it feel. Make sure all the suspension arms are torqued and show no bends first though.
I would think the wheel is bent, rotor is warped, or the tire is out of balance, before thinking its a hub... unless your axle is broken.
