Rear tire comes off car while driving
versaa25
Car: 2012 Nissan Versa - 1.6L
Nissan Versa 2012 1.6L / Standard Shift
I am seeking information as to how the rear tire (including the drum) can come completely off of the car.
Last week, I had my car serviced at an auto repair shop. I had the front and rear brakes replaced. On the front, new pads were installed. On the rear, new shoes, bearings and drums were installed.
Here is a brief description of the incident. Within a span of 30 seconds the following occurred:
1) ABS Light came on;
2) The steering wheel began to shake violently;
3) Depressed brake to slow down when;
4) The TIRE, while still attached to the drum came off of the car and went flying 150meters out into the woods.
5) When the car stopped, I examined the rear of the car where I found the rear brake completely exposed. The main nut is visable and firmly holding the bearing behind it.
Could anyone help me solve this problem? How is a tire able to come completely off of the car like this?
versaa25
Discovered the problem.
After the bearing had been pressed inside the drum. The mechanic did finish the job by putting the c-clip that holds the bearing in. They were left in the old drums.
Very disastrous, as the c-clip is the only thing holding the drum onto the bearing.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Good information ,thanks for sharing it.
Welcome to NICO!
