b. Release the gas pedal, coast down, then pull to the side.and, this is the proper procedure for a front blow out too...loystock wrote:The 'G' is one of the finest cars on the road. We lost our G last March and really missed it. So I'm asking this question to the forum members to find out the percentage of people giving the correct answer. Please give an honest answer. The Hazard lights are presumed to have been turned on.
In case of rear tire blowout, what is the appropriate response? a. Step on the brake and pull to the side as soon as possible.b. Release the gas pedal, coast down, then pull to the side.c. Step harder on the gas pedal and then pull to the side as soon as possible.d. Call 911
I think the proper term here is coast down. I would not do much more than put in the clutch on a manual or simply coast off to the side and allow the car to stop with as little assistance as possible.bschurr wrote:
PS - I believe your question would be better answered by creating a poll
The last thing you want to do is to have a wheel with a compromised tire stop rotating. You saved the wheel and stopped in a controlled fashion.RichiePoor wrote:Well this has happened to me in my G and I was on a bridge. I released the gas pedal and coasted to the exit. I pulled over and realized that there was a hole in the side of the tire (Kumho) about the size of a quarter. The tire did not shred and only the rim was damaged. So I am going with B. I had a Goodyear tire on a Sentra one time and it shredded into pieces and ripped the rear bumper off the car.
May work on a FWD, however on a RWD probably best to just coast to a stop so as to not lose control and to limit any damage.Tampa G35 Sedan 6MT wrote:I would go with B as well
Actually I would down shift to bring the car to a stop... that way you don't lose control.
Probably by applying the three brakes they have left.Kendahl wrote:Definitely B.
The incident makes me wonder why people lose control after a blow out. Perhaps it would have been different if I had lost a front tire.
Be in the cop car following her?loystock wrote:My daughter did the most logical course of action, which most of you agreed to - release the gas pedal (b), yet she lost the car. If some of you have been watching the COPS TV series, you may have an idea about the right answer.
I don't think either one of these are really in conflict with the link I posted above. Keep in mind that step one in my link is to determine what has occurred prior to following your course of action. That is when you remove you foot off of the accelerator. The police videos show all sorts of different cases with spike strips which wipe out mulitple tires. Also you are looking at reality tv which is not reality.loystock wrote:She did not turn on the hazard lights. I just added it for the sake of other people who insist that hazards lights must be turned on first in case of emergency. In fact, one of them already posted earlier.
I agree with you that corrective action must be done first - take control of the car before turning on the hazard lights or signal lights..
In her case, she just released the gas pedal and tried to control the car. Unfortunately, her forward momentum was not enough to offset the effect of the blown tire and her car drifted to the other lane, hit another car, spun out of control and then hit the center divider. The other car just had a small dent on the driver's side door. My daughter was shaken but not hurt - thanks to G35's airbags and curtain airbags.
The worst thing to do in case of a rear tire blow out is immediately stepping on the brake. You will definitely lose control. Releasing the gas pedal immediately may or may not allow you to control the car.
The best course of action in case of a rear tire blowout is to depress harder on the gas pedal (to maintain vehicle momentum) until the car can be driven straight and under control. Once the car is under control, slow down, signal (or hazards), and then pull to the side of the road. Once stopped, turn on the hazard lights.
For years, I've been telling my friends about stepping on the gas in case of a rear tire blowout and most of them disagreed. Some even thought I'm crazy. You have probably have seen the 'bad' drivers in the COPS TV series whose car tires got spiked by the police yet still driving straight...just because they got 'pedal-to-the-metal.'
I found this site last year and finally convinced my friends about what to do in case of a rear tire blowout.
http://www.edmunds.com/ownersh....html
Here's another one from TireRack
http://www.tirerack.com/tires/...id=13
