nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Wed Jan 30, 2013 6:41 pm
Center carrier bearing on the driveshaft. Check that as well as the rear diff bushing, but they will really thump when you hit the gas and let off the gas with the car in gear. With the bearing, go under the car, find the shaft and if you can move it up and down, its bad.
