my stop lights dont work. (normal driving) when i press on the brakes, the rear light does not come on. (when front lights are switched on) the back lights go on, but when i press on the brakes, the stop lights dont work. there should be another brighter shade of red. instead it stays that dim red color. i've changed the bulbs. and checked the light fuse, i've been doing some reading on here, and someone was talking about the stop light sensor? i've looked under the brake pedal, and that rubber circle thing is still intact so i know its not that. um the top third brake light was cut by the previous only, could it be the stop light sensor? i dont know if its a ground or a short, all the wires look fine. but im know electrian tech. also what fuses should i be checking for? and i have like 4 fuses missing. CIG Light 15A, Electronic IG <- what is that for? RC Mirrors, and under light control there is a blank, but on this picture its the daytime lights.
do i need to put a fuse in that black spot? and what is the electronic (IG) for? what does it do? is that important? my car is a 1990 240sx fastback. much help is needed and very appreiated.
thanks.
