Not when you count the links and rod ends.louiegz wrote:I'm looking to get the rear sway bar and I'm doing some reserch. That totals to $158.70. A savings of $103.08. I'm wondering if the cheaper kit is complete. What do you guys think? Does it sound complete?
elwesso wrote:Im not sure, but Ive dealt with Joe enough to know that he WONT cut any corners
louiegz wrote:I'm looking to get the rear sway bar and I'm doing some reserch. I've herd mention on the forum that you can buy the Rear Stabilizer Kit - Q45 '90-'96 new on http://www.infinitipartsusa.com for $261.78. I was looking on Pinnacle Nissan/Infiniti Online Parts Warehouse http://www.nissanparts.org and they sell the bar and all the parts. I droped the parts guy an email and he said the part were...
1 bar 143.162 bushings 3.23/each2 brackets 2.80/each4 bolts .87/each
Rex wrote:adding the rear sway bar without installing the smaller front bar will not give the desired/designed results.
louiegz wrote:...I'd do the search of the older post myself, but the search box dont seem to be working right. I cant get anything past Dec 10th for some reason...
louiegz wrote:...what is the worst that can happen if I leave the 29mm in place? Will the car become undrivable?...
louiegz wrote:Because after I do the Tokicos, the tension rods, bushings and whatever else can go wrong with a 9 year old car, I'm going to have to live in a van by the river.
Q45tech wrote:Do the rear bar first and the lowering springs only if you absolutely have too!!!!!!!!!!!!!!!!
Even though I have them I keep wishing I had never lowered the Q as the gain [from the springs] doesn't cover up the ride deficit and the camber problems...............not to meention the faster shock/tire wear.
But a firmer ride with less suspension travel for a given input and better behavior when loaded is what I would hope to accomplish. The car is a little too vague when fully loaded with four people on board.Q45tech wrote:Stiffer springs at the same ride height don't help reduce the center of gravity so the tire loads are the same.......No GAIN! other than less sway but that what you use sway bars for.
