rear sway bar on 97
Hurrikane
Car: the car
were can i find a rear sway bar for my 97 240. and a harness bar for 6 point seat belts. a rear floor brace would be nice to
Spec-R
how did you take the speed limitor off????? and what kinda cold air short ram intake you got???
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
there are several ways to remove the speed limiter.. The easiest and dirtiest way is to remove the speed sensor. The nicest and most expensive way is to get a reprogrammed ECU
PGBrian
head over to http://www.jspec.com for those items.
Hurrikane
Car: the car
ok most of the parts that thay have are jdm cars and not usa cars. the rear bar has a lop for the pipe on the right side and not the left. but i will say that i have all of that on the car at this time. i had it all made at my shop. the real bar only cost me $35.00 to make and not 400+. as for the limeter.after you cut the yellow wire with green strip.this wire is under the purplewire with a white stripe. thay are just under the bolt that hold the block to the cpu. after you do this you need to go under the car and unplug the 4 and 5 gear switches. one is on the top of the trans and one is just below it on the side. after this is done the car will go over 115mph. and yes evry thing in the car will still work.
PGBrian
hey guess what.suspension parts for USA and JAPANESE s14 are the same. the only thing off the top of my head that i can think of that is different is a brake master cylinder stopper.everything else will fit. we don't have a 4th gear sensor.i think you are very confused. just keep living life that way. i don't care.
BuudWeizErr
hahahahaha.
idiots owned by brian. i love it. makes my monday morning that much more awesome.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i think the 4th gear sensor is for speed cut, 5th gear is speed and rpm cut...right?
Hurrikane
Car: the car
You got it man.thay still work as one and need to be remove. and that rear bar doest work on my 97.
