Unfortunately the car this is coming off of did not come with a rear sway bar, and that Q45 only came with 3 options, no bar, 16mm bar and a 20mm bar and No one makes any after market bars for it.
As I'm led to believe from all the reading i can find on-line, this sub frame is a bit of a combo between the Z32tt and Z32NA frames.
If anyone has a Z32 rear sway bar around that they could measure, could you fill in the measurements shown in the following picture?
This will let me see if a Z32 bar could be used. As all the rest of the suspension linkages are swappable from a Z32, this will allow some available upgrades while swapping into a Z31.
This way i can compare to the mounting points on the sub frame from the car.
Thanks
