Sway bars should only be used to fix handling balance issue's, to fine tune the car to your style so that you can extract the most performance that you are capible of getting out of said car. A rear bar only is not the way to go to improve these car's in a meaningfull manner. If you just have to do it, get the EVO350 rear bar as it can be set to very mild stiffness increases. As a example:
The OEM rear bars torsional deflection rate is 380 lbs/in
The 350EVO rear bar in each of it's 3 possible settingsSoft 370 lbs/inmiddle 475 lbs/instiff 580lbs/inORsoft -8% softermiddle +11% stifferstiff +33% stiffer
Best thing to do is to get a adjustable front and rear set of sway bars, Hotchkis ($250) Eibach ($319) or 350EVO ($360) install them mildly set. Then do the testing described below and adjust them as needed.
http://forums.freshalloy.com/u...=5&o=
Adjustable bars are NOT just to do with racing or autocrossing and everything to do with allowing you to take full advantage of why you choose to add sway bars in the first place. Even if you install them and never adjust them more then once, they allow you to set the car up better the first time around and to make changes when you need to.
I do not support rear bar only moding on these cars.
One could dig a lot deeper on the topic in general, but that would be pointless overkill.
