Rear Sway Bar Bolt Size
96'er
Car: 1996 Q45
I just received a Q45a rear sway bar and was not shipped the bolts that mount the sway bar to the frame. My local Infiniti dealer was no help, so can anyone tell me what the pitch and length is for these four bolts?
Thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So where are you obtaining your bushings and end links?
I ask because I just bought mine from Joe when I added the a model bar.
Modified by maxnix at 7:40 AM 5/1/2008
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Yes!!! I thought these pics would come in handy some day. Hope this helps.
Length: 12.5cmThe top bent one is from a Q45 Active. The bottom one is from a Q45.
Q45a pieces on the left. Q45 pieces on the right.
This is how it looks:
Top
Bottom
And if you get cocky this is what will happen:
96'er
Car: 1996 Q45
Maxnix:
I got my bushing links from Napa Auto, Item #18184, from this tech article, http://www.nicoclub.com/articles.php?id=170115
The kit comes was less than $20 and comes with all new washers, bushings and bolts.
Kiven422:
Do you have any information on the bolts that hold the sway bar to the frame, those would be the half-moon brackets?
Thanks.
NOR*CAL 916
Car: 1994 infiniti q45
the bolts on the half moon brackets are 14mm if i remember they are 12x1.25, the bolts on the front sway bar are the same as the rear.
96'er
Car: 1996 Q45
Actually the bolts are M10-1.25x30.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks for the updated information!
