Rear suspension - What to do?
BryanWSD
Car: 2010 Infiniti G37S Sedan
2002 Nissan Pathfinder LE 4x4
So, after reading too much, I'm noticing a little "sag" in my baby's trunk. (yes, I'm talking about the truck).
Only 61k miles. Would you worry about it?
It's tough to tell in the pic, but my driveway is sloped a little down. I checked the shocks, and I have a little leakage on the driver side rear shock.
jimmyzzer
Car: 1999.5 nissan pathfinder
the rear factory springs are weak.my truck was bottoming out.these are alot better than the factory springs.http://www.4x4parts.com/public...97f68
BryanWSD
Thanks for the link. Does the 1/2 inch lift look funny if you don't do the front?
jimmyzzer
it will sit high at first till the springs settel down then it should look ok.
Mr Nice
Car: R50 4x4
a leaky shock will not affect ride height. it is the coil spring which supports the weight of the vehicle.
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
leaky shocks need to be replaced. i had to replace mine. push the back and see if the back bounces up and down. if so, time for replacement.
Pathy35SE
Car: 2002 Nissan Pathfinder 3.5 SE
I don't know if this has anything to do with your situation, but I'll throw this out nonetheless...
About 6 months after buying our 2002 (new in June 2002), I noticed the rear end was a bit saggy... like someone was sitting in the backseat... even when they weren't. Also, when my kids were in the back while driving, the rear would bottom on occasion. Both items surprised me considering the Pathfinder is such a genuine SUV with a truck-stiff suspension. Something seemed wrong.
Found out about a TSB about the big solid rubber inserts inside the rear coil springs that cure the bottoming out and rear sag. Dealer ordered the replacement "bump stops" immediately. Once installed, it cured the rear sag. And no more bottoming to this day. The difference was and still is remarkable. Other than that little hiccup and a blown fan controller, our Pathy has been near perfection... just hitting 60K miles.
This TSB I mentioned might help solve your problem. Then again, it might not apply to you.
Good Luck.
