Not quite sure what you are saying. If there was no resistance when pushing your rear end down, that would mean that you must have no springs. If you had no springs, you would be tucking tire in the rear most likely. I reallllly doubt that you are missing your springs, so there must be some resistance. The stock suspension is just soft, thats all. If the ride is really bouncy, you could have blown struts. This means that there is nothing damping the compression of the spring, so it will occilate back and forth much easier that if it were damped. Damping rates are not really something that is measured. spring rates are.XerouShift96S14 wrote:Yeah I've been doing that, I wanted to know acutally should my rear shocks be that soft, where you can just push my rear end down and it will come back up, no reistance at all?
I'm sort of a noob when it comes to suspension, drivetrain and everything else I can usually go at without any problems, I just have a hell of a time figuring out what dampening rate to use and all that.
Thats it exactly, plus you know the rubber dust guard boot, well mine are in shreds, and have fallen down into the springs, in fact my rear suspension is so shot that I can easily lose cornering in the rain, even at 20mph, running 25psi in my tires to increase contact patch.naed240sx wrote: If the ride is really bouncy, you could have blown struts. This means that there is nothing damping the compression of the spring, so it will occilate back and forth much easier that if it were damped.
Ah wasn't me who did it, previous owner had a wreck in it and the dealership fixed the car, I gotta get a new bolt to torque down a crossmember in fact, also why I need new headlights as the brackets in the ones on the car are zip tied to the frame ( ).naed240sx wrote:Running that low of a psi in your tires is probably not a good idea. It can actually decrease your usable contact patch, and cause controll issues. If you are just cornering on flat ground, your struts shouldn't make that much of a difference. You probably just aren't used to rwd. Under throttle, in the rain, it is really really easy to start spinning in a 240. You can get good factory replacement struts for pretty cheap, or go with some better ones that will support the use of some higher rate springs if you want. That information can be found by searching.
1 question, why do you have a rebuilt engine and new transmission in an s14 with 105k miles? KA motors last forever if taken care of. Past 200k no sweat. Hard to believe that your struts are going out this quikly too. I bought my 93 s13 at 150k, and the stock springs and struts were doing decent. The boots you speak of were all torn up, but the ride was ok. I replaced them with coilovers though.
naed240sx wrote:Key word: usable. I didn't say that lowering the psi would decrease contact patch. When lowering the psi like that on a standard tire, the tire deforms, and will loose grip and become unpredictable.
