Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sat Jan 21, 2006 5:02 am
I have an air compressor, spring compressor($20 from Auto Zone), a nice floor jack, and jack stands.
I can park the car, remove the panels in the trunk, remove the 4 nuts holding the tops of the struts, jack the car up, take off teh rear wheels, remove the lower bolt, take out the strut assemblys, remove the springs, put the springs on the new struts (and the new dust boots), re-install the strut assemblys, re-install thw wheels, re-isntall the rear panels of the trunk, and lower the car in about 2 hours.
It is a very simple operation.
This will tighten up the rear of the car about 500%. Definitley go with Tokiko Blues. Buy all 4. Get the dust boots from Joe (Everything NISSAN-INFINITI add on the right of your screen).
If you have a few hundred more, get the rear sway bar kit from him too. It takes about an hour to install. You have to disconnedt all the exhaust mounts and let the pipes hang down, to get it installed. Then spring for new tension rods and uper links up front, when you do the front struts. They only take about 2 hours as well.
Once you get all this done, buy my front strut tower brace, and the car will handle great.
