DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sat May 29, 2004 1:05 pm
By "compressing the suspension" I mean that *after* bolting up the lower strut bolt, you will need to raise the wheel hub to it's natural height...the height it's at when the car is sitting at rest. The bushings in the links are under torsion when the car's suspension goes up and down on the road. You want to make sure there's no torsion at rest, otherwise the bushings will fail much faster. You will see this when you remove the links. Each link you remove, the hub will fall a little lower down becuase the torsion forces in the bushings are what's holding it up.
Perhaps there is another way of doing this, but I pulled off the assembly with the lower link attached. Only after I got this off did I have enough room to remove the lower link from the hub assembly. I needed a puller, though you might have better luck. Then you can remove the hub assembly (with bearing) from the knuckle assembly and splash guard, and the parking brake as well. Once the knuckle assembly is out you can take it to get the bushings replaced (and ball joint if you have HICAS).
I just pulled everything off...easier to work on things on a bench than on the car. The hub and the knuckle are held together with 4 bolts. Warning...the lower arm has a ball joint that I don't think is replaceable. Also, each link has a bushing that isn't replaceable. I ended up replacing all links.
