2008 Rogue SL.
I changed the shock absorbers to KYB a couple thousand miles ago and I'm still getting clunks from the rear suspension. I've also replaced the sway bar bushings recently. So much of the internet focuses on the front suspension and I've got problems all around.
The clunks come when the leading edge of the rear tires hit a bump. It seems to be on both sides. Any ideas? I'll look for loose bolts/nuts. The exhaust bushings seems ok. Nothing obvious visually.
