rear suspension links!! need help
weeble
Car: 1990 240 sx
hey everybody. i just got megan racing coilovers and 17x8 5zigen wheels with 225/45 pirelli pzero neros all around. i was able to get the front of the cars alignment back into spec because of the camberpaltes that came with the coilovers. the rear however have no camber plates. I currently hace 3 deg. of negitive camber in the rear on bot tires. the toe is correct however. what i am considering doing is buying the Battle Version Rear Suspenion Package, from phase2 to correct the camber and toe, also to take some of the slop from the rear end. does this sound like the best soulution to you guys? thanks alot!
chmercer
go with splparts. http://www.splparts.com. competitive pricing, and, in my opinion, better customer service and quality. you do not need full rear links, unless you want them. All you need to alter your rear camber is a pair of rucas (rear upper control arms.) also consider adding more camber to the front of the car, because, well, stock alignment specs suck ***.
weeble
Car: 1990 240 sx
thanks for the advice. i will check them out. my experiences with phase2 have been great and they always help me out and there local so i will stil probobly go with them. what do you guys think of battle suspension compared to cusco per say.
chmercer
cusco is better imho.
vs
easy choice for me.
naed240sx
Car: .....
-3 degrees in rear? dont you think thats pretty excessive lowering? I lowered mine about 1.5 in rear and 2 in front, and the rear camber was only a -1.5, no need for adjustable arms, but I am putting on some bolts to fine tune it.
Nismo_Freak
Car: 89 Nissan 240SX
My S14 was lowered about 2.5" and had about 3.5 of rear camber. There are differences in subframes.
100% Pro SPL Parts... there are ZERO parts that are stronger than the Cusco RUCA's and thats why SPL sells them.
