Rear Subframe
Yoda's Master
Car: 2012 M56
2009 370z
You guys might want to check if this has happened to you as well.
I had my car on jack stands and noticed the rear subframe was loose.
Ilya
How'd you fix it or what is the fix? Are we looking at the gap between the cylinder/disk?
Yoda's Master
Car: 2012 M56
2009 370z
Ilya wrote:
Sun Feb 28, 2021 8:28 am
I didn't yet. I'll do it after i receive my Z1 bushing collars so i can install it and tighten up at the same time.
Yoda's Master
Car: 2012 M56
2009 370z
Well this sucks. I was prepping the rear to install the bushing collars that will be delivered later today and see the nuts holding the subframe are tight so that just means the bushings are shot. Anyone know where they sell just the bushings?
Yoda's Master
Car: 2012 M56
2009 370z
This is a dead bushing :mad:
Yoda's Master
Car: 2012 M56
2009 370z
Well, I'm going to spend $100 to try and save $1500. Picked up some poly bushings that I hope will fit. I can't seem to find an aftermarket poly diff bushing :tisk:
those q50 folks need to start breaking their subframe bushings :gapteeth:
Yoda's Master
Car: 2012 M56
2009 370z
This looks promising. The poly bushings i bought looks like they'll fit with a slight modification. The front looks like it'll fit up as is, but the rear looks like it'll need two 3/16" spacers to fit up properly.
I'll swap them out after I get my prop shaft recall completed.
I was thinking of just cutting off that top flange and using the stock isolation ring since it's 3/8" thick, but the bushing would protrude a bit on the top and i didn't want the subframe to have that extra amount of movement so I'm looking at finding either aluminum spacers or delrin spacers.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yoda's Master wrote:
Sat Mar 13, 2021 6:09 pm
Try McMaster-Carr and not the parts store, they have more kinds of offbeat washers and spacers than anyplace else in the western world.
Yoda's Master
Car: 2012 M56
2009 370z
VStar650CL wrote:
Sat Mar 13, 2021 6:15 pm
Their checkout process sucks and shipping isn't as cheap to me than it is to you so I'm scouring the internets and local places for material. I think i might just cut off that flange and got with a 3/8" thick spacer instead of two 3/16" spacers.
Yoda's Master
Car: 2012 M56
2009 370z
Teaser
Yoda's Master
Car: 2012 M56
2009 370z
What do you guys think about the diff bushing? It hasn't blown yet, but also doesn't look too good.
I think I'm going to pop it.
VStar650CL
Technical Expert
Looks like it's dried out and fixing to tear, I'd say replace it while you have it off the car anyway.
Yoda's Master
Car: 2012 M56
2009 370z
I wish there's aftermarket solution out there, but there's not. Gonna just pop it and poly fill the cavity.
VStar650CL
Technical Expert
Mon Apr 05, 2021 12:12 pm
Better than nothin'.
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
Yoda - Measure the diameter of the Diff bushing....I have a solid bushing (g37) sitting on my desk as a paper weight. Would love to know if it is the same diameter. I could even send you it to see if it fits (Its solid aluminum so I'm not sure you'd want that for NVH)
Yoda's Master
Car: 2012 M56
2009 370z
ken in az wrote:
Wed Apr 07, 2021 9:51 am
Thanks Ken, but it doesn't. I checked that already and the M diff bushing diameter is about double at 90mm diameter x 66mm long.
I cleaned off the surface rust, gave it a coat of paint, popped the the silly-cone sacs, and washed it as best as i could. My poly is on the fedex truck out for delivery. The 1 week cure time sucks.
Yoda's Master
Car: 2012 M56
2009 370z
I think it looks a lot better now
C6Joe1957
Car: 2012 Infiniti M56 Sport
2008 Infiniti G37 Journey Sport
That looks amazing! What poly did you used for the repair?
Yoda's Master
Car: 2012 M56
2009 370z
C6Joe1957 wrote:
Fri Apr 09, 2021 9:36 am
I used this https://www.suspension.com/diymmi
Shore 84A HP. You could probably do with shore 60A.
I used less than half the can so lots of waste. Down side is the 1 week cure time.
C6Joe1957
Fri Apr 09, 2021 2:48 pm
Thanks for the link! It's states that you can cure it faster (18 hours @ 150°F). If you have a big enough oven. :rotfl
I'm having a bit of a rattle/groaning in the rear and thinking of doing it with the 80A which is a compromise of being a little quieter with some medium stiffness versus the 80A-HP or 94A.
Yoda's Master
Car: 2012 M56
2009 370z
C6Joe1957 wrote:
Fri Apr 09, 2021 6:23 pm
That's a fine choice as well. You do need to drop the subframe to do the work. You might as well go all the way and replace the other four
Yoda's Master
Car: 2012 M56
2009 370z
Front diff bushing
The gaps looks much better
Yoda's Master
Car: 2012 M56
2009 370z
BTW if your subframe is loose, then you'll want to get that addressed asap. I had to finagle the driver side stay to get it to bolt back up.
Yoda's Master
Car: 2012 M56
2009 370z
Everything is done and the rear end feels very responsive. Acceleration feels quicker and I haven't noticed any additional noise or vibrations.
