Well I was driving down a local road, going 60, and I noticed that my rear end swayed a lot. A lot more than it should. When I got home I took a look at the rear subframe, I noticed that there was was about a quarter inch go from the chassis to the subframe, around the area where you bolt it up to the chassis. I tried to tighten all bolts by jacking up the subframe by the diff and removing the said slack, but they were still tight and gap remained after I dropped it. Is this gap normal? what would cause this sudden problem for the rear subframe to sway like this?
I also noticed that the collars (they go on right before the final nut to finish bolting the subframe to chassis) was visible. I think, iirc, that the subframe was supposed to 'hang' over those collars.
Is this why my car could be swaying at moderate speeds; That gap from the chassis to the subframe?
Let me know if you need any clarification, ANY help is appreciated and I need to get this fixed asap, doesn't feel safe at all.
