lbrowne wrote:just wondering if you could answer my question?
Sorry about that. I've been fighting lawyers... Takes up most of your time and energy and you just forget about things.
lbrowne wrote:For a daily driver, thats not lowered and probably won't ever be, how would you rate these bushings? I'm afraid of making the ride harsh - thats what my TA is for...
I think the bushings are great. I love them. Road noise is minimal, but above normal since you do have metal against metal now. As for harsh... Stiffer yes, firmer yes, harsh... I would have to say no on this one. If you are on a good road/track these feel smooth as can be to me. Now, if you hit a big pot hole your going to feel it a little more than rubber bushings, for sure. I drive my 240 about every day of the week and love the ride.
P.S. I am going to get my car lowered but only a small bit when I start replacing suspension, tires and rims.
n00b240 wrote:nice update 7anshin, do you hear any new whines, drones, or added sound scores since the install?
A little more road noise, not much. I guess the best way to describe the sound is a quiet hum from the rear end, nothing that has bothered or been noticed by a passenger.
ADiamond75 wrote:At first I thought this was true .. but the bummer is once the subframe bushings get to a certain point NOTHING can save them but replacing them.
I had the infamous subframe problem (chunking / skipping in corners / clunking from rear end) and tried the subframe spacers from Kazama ... yeah they fixed the problem for about 4 months ... then the problem came back and only got worse. By the time I got around to replacing the entire bushings in the subframe there was almost nothing left of the front ones ..
Today makes one month to the day that I installed these and they are still holding up great, for now. I figure these will go one day, rubber only lasts so long. I will post if they do, I will also keep everyone informed as to how these are holding out every couple of months.
n00b240 wrote:You cant really notice the noise of the solid bushings outside the car
How does it sound from inside the car? I'm with you on the rubber will eventually wear out part. I'm thinking solid in the future but how harsh is that ride in a daily driver?
